[Fwd: [Fwd: Re: [postgis-devel] Re: Patch for PostGis Envelope Bug]]
Charlie Savage cfis at savagexi.com
Fri Sep 21 22:33:18 PDT 2007
And take #3 - missed the SRID values for points and lines in take #2.
Charlie
Charlie Savage wrote:
> Ok - here is take #2.  This hopefully is much better - I should have
> done it this way to start.
> Note that the 3 methods are now almost 100% identical (LWGEOM_envelope,
> BOX2DFLOAT4_to_LWGEOM, BOX3D_to_LWGEOM).  The only difference between
> them is how to get the bounding box (1 line of code at the top of each
> method) and then for envelope to set the SRID.  It would make sense to
> have just 1 method that does most of the work, and have the original 3
> wrap it.  Would you convert Box3d to Box2dfloat or the other way around?
> Anyway, here are the examples again, plus a few more.  See how they look.
> select asText(envelope('POINT(10 10)'::geometry)) AS G1,
>        asText(envelope('MULTIPOINT((10 10))'::geometry)) AS G2,
>        asText(envelope('MULTIPOINT((10 10), (10 10))'::geometry)) AS G3,
>        asText(envelope('MULTIPOINT((10 10), (20 20))'::geometry)) AS G4,
>        asText(envelope('LINESTRING(10 10, 10 50)'::geometry)) AS G5,
>        asText(envelope('LINESTRING(10 50, 50 50)'::geometry)) AS G6,
>        asText(envelope('LINESTRING(10 10, 50 50)'::geometry)) AS G7,
>        asText(envelope('MULTILINESTRING((10 10, 50 50))'::geometry)) AS G8,
>        asText(envelope('MULTILINESTRING((10 10, 50 50), (20 20, 70
> 70))'::geometry)) AS G9,
>        asText(envelope('MULTILINESTRING((10 10, 10 50), (10 20, 10
> 70))'::geometry)) AS G10,
>        asText(envelope('POLYGON((10 10, 50 50, 30 30, 20 20, 10
> 10))'::geometry)) AS G11
> g1 "POINT(10 10)";
> g2 "POINT(10 10)";
> g3 "POINT(10 10)";
> g4 "POLYGON((10 10,10 20,20 20,20 10,10 10))";
> g5 "LINESTRING(10 10,10 50)";
> g6 "LINESTRING(10 50,50 50)";
> g7 "POLYGON((10 10,10 50,50 50,50 10,10 10))";
> g8 "POLYGON((10 10,10 50,50 50,50 10,10 10))";
> g9 "POLYGON((10 10,10 70,70 70,70 10,10 10))";
> g10 "LINESTRING(10 10,10 70)";
> g11 "POLYGON((10 10,10 50,50 50,50 10,10 10))"
> Martin Davis wrote:
>> Charlie:
>> If the examples you give in the email below are actually what your
>> Envelope patch is doing, this is WRONG!
>> The envelope of non-horizontal/non-vertical linestrings will always be
>> a Polygon, not a Linestring.  Only exactly horizontal  or vertical
>> linestrings will have an envelope which is itself a LineString.
>> The way this should be implemented is to first compute the true
>> extents of the geometry.  Then check the X &Y extents and return the
>> appropriate geometry constructed from the extent ordinates.  The JTS
>> code that does this is:
>>  public Geometry toGeometry(Envelope envelope)
>>      // null envelope - return empty point geometry
>>    if (envelope.isNull()) {
>>      return createPoint((CoordinateSequence)null);
>>      // point?
>>    if (envelope.getMinX() == envelope.getMaxX() && envelope.getMinY()
>> == envelope.getMaxY()) {
>>      return createPoint(new Coordinate(envelope.getMinX(),
>> envelope.getMinY()));
>>      // vertical or horizontal line?
>>            || envelope.getMinY() == envelope.getMaxY()) {
>>        return createLineString(new Coordinate[]{
>>          new Coordinate(envelope.getMinX(), envelope.getMinY()),
>>          new Coordinate(envelope.getMaxX(), envelope.getMaxY())
>>    return createPolygon(createLinearRing(new Coordinate[]{
>>        new Coordinate(envelope.getMaxX(), envelope.getMinY()),
>>        new Coordinate(envelope.getMaxX(), envelope.getMaxY()),
>>        new Coordinate(envelope.getMinX(), envelope.getMaxY()),
>>        }), null);
>> -------- Original Message --------
>> Subject:     [Fwd: Re: [postgis-devel] Re: Patch for PostGis Envelope
>> Bug]
>> Date:     Fri, 21 Sep 2007 16:11:51 -0700
>> From:     Kevin Neufeld <kneufeld at refractions.net>
>> To:     martin Davis <mbdavis at refractions.net>
>> Subject:     Re: [postgis-devel] Re: Patch for PostGis Envelope Bug
>> Date:     Fri, 21 Sep 2007 15:05:54 -0600
>> From:     Charlie Savage <cfis at savagexi.com>
>> Reply-To:     PostGIS Development Discussion
>> <postgis-devel at postgis.refractions.net>
>> References:     <46E09936.5030008 at savagexi.com>
>> <9245.1189132424 at sss.pgh.pa.us> <46E0E199.40302 at savagexi.com>
>> <46E13929.5090400 at vadose.org> <46E1739D.6030800 at savagexi.com>
>> <46E181A2.6050309 at refractions.net> <46E18A30.2000002 at savagexi.com>
>> <46E18B76.4000508 at refractions.net> <46E39FDC.3040005 at savagexi.com>
>> <46F09E3B.4080209 at savagexi.com>
>> <7F743A6F-517E-498F-A3D7-23793727D60A at refractions.net>
>> <46F43097.4010503 at savagexi.com>
>> And here is an example of its use:
>> select asText(envelope('POINT(10 10)'::geometry)),
>>        asText(envelope('MULTIPOINT((10 10))'::geometry)),
>>        asText(envelope('MULTIPOINT((10 10), (20 20))'::geometry)),
>>        asText(envelope('LINESTRING(10 10, 50 50)'::geometry)),
>>        asText(envelope('MULTILINESTRING((10 10, 50 50))'::geometry)),
>> 70))'::geometry)),
>> 10))'::geometry))
>> "POINT(10 10)";
>> "POINT(10 10)";
>> "LINESTRING(10 10,50 50)";
>> Charlie
>>> Hi Paul,
>>> Paul Ramsey wrote:
>>>> Applied to trunk. I don't see any way it can do harm.
>>> Here is patch to the patch (thus it applies against the trunk).
>>> It adds in support for returning a LineString if envelope is called
>>> on a line string (thus making this similar to the  bbox to geom
>>> conversion routines).
>>> Also, it fixes a bug I introduced in the last version (not checking
>>> to see if the deserialized geom should be freed).
>>> Thanks,
>>> Charlie
>>> postgis-devel mailing list
>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20070921/52b539b8/attachment.ksh>
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20070921/52b539b8/attachment.bin>
