API for optimized predicates (was Re: [postgis-devel] 1.3.3)
Ben Jubb benjubb at refractions.net
Tue Apr 1 17:12:31 PDT 2008
for the 3 param version, where you using an integer key, or NULL?
b
Paul Ramsey wrote:
> I gave this a try, but in the three-parameter case it caused the
> backend to crash and in the two-parameter case provided the same speed
> as the usual un-prepared approach...
> I was testing with st_contains(polycolumn, pointcolumn), with 80 polys
> and 7000 points.
> P
> On Mon, Mar 31, 2008 at 3:50 PM, Ben Jubb <benjubb at refractions.net> wrote:
>>  Hiya,
>>  I've attached a patch to lwgeom_geos_c.c, modifying its 1st arg caching
>> behaviour.
>>  The third argument is used as before, as a surrogate key, and the caching
>> will use that as its key;
>>  UNLESS the key is NULL.
>>  If the key is NULL, the predicates use the memcmp technique to determine if
>> the cached prepared geometry is in sync with the first arg.
>>  Note that the two caching approaches have essentially independent caches.
>>  This patch is intended for testing purposes only.
>>  enjoy
>>  b
>>  Paul Ramsey wrote:
>>  A unique-on-insert ID would be another approach. It would, however,
>> involve a disk-format change, so we're talking about pretty big
>> hammers here, regardless of whether we did a hash or a uuid.
>> Ben, maybe just stick some small timing statements into your current
>> code... start time, end time, and then do a noop memcmp with start/end
>> times as well. That way we can compare the memcmp times to the total
>> times.
>> P.
>> On Mon, Mar 31, 2008 at 10:17 AM, Martin Davis <mbdavis at refractions.net>
>> wrote:
>>  (renaming this thread, since the current one is way overloaded)
>>  I agree with Paul and Mark - there should be a simple function signature
>>  for the fast preds. The more complex one can be provided as well, but
>>  it will need to be VERY well documented, since it's a tricky thing to grok.
>>  re spatial hash - would you really trust a hash to confirm identity? I
>>  don't think I would...
>>  Would another alternative would be to assign a hidden unique ID to each
>>  geom entered into the DB. This could be a honking big integer, or maybe
>>  a UUID.
>>  Paul Ramsey wrote:
>>  > The problem is that the memcmp hit gets worse in exactly the cases
>>  > were we expect better and better performance from the prepared
>>  > algorithm... still, it would be nice to know what that hit is...
>>  > compared to the original, unprepared time, it will be small, but
>>  > compared to the prepared-with-id-API implementation... hard to say.
>>  > Something to resolve before 1.4... It's unfortunate that all the
>>  > *fast* tests can only falsify identity, not confirm it. I was talking
>>  > to a fellow who has done a spatial db implementation on a proprietary
>>  > system, and he was pleased with the idea of a "geographic hash" that
>>  > he can calculate for each shape and use to test identity. If we were
>>  > to do something like that, it would have to be optional, like the bbox
>>  > calculation is currently.
>>  > P.
>>  > On Mon, Mar 31, 2008 at 2:51 AM, Mark Cave-Ayland
>>  > <mark.cave-ayland at siriusit.co.uk> wrote:
>>  >> On Friday 28 March 2008 23:53:53 Ben Jubb wrote:
>>  >> > Howdy,
>>  >> > In my testing, I did see a performance hit when using the memcmp test,
>>  >> > although it was noticable only in the largest of my test geometries
>>  >> > (5000 vertices or so).
>>  >> > The three parameter form seemed like the best way to go because the
>>  >> > whole point of the prepared version of the functions was to get the
>> best
>>  >> > possible performance. The cases when the performance matters most is
>>  >> > with large geoms, and then the cost of doing the memcmp is the
>> highest.
>>  >> > Using a third argument seemed the simplest way to get the best
>> possible
>>  >> > performance from the predicates, with a minimal increase in the
>>  >> > complexity of the interface.
>>  >> > I agree it would be nice to have a single form for those predicates
>> that
>>  >> > automatically determines the most efficient manner to do the tests,
>> but
>>  >> > there didn't seem to be any efficient way to accomplish that.
>>  >> > b
>>  >> Hi Ben,
>>  >> Well I think it really comes down to what exactly is the performance hit
>> and
>>  >> how did you measure it? Which platform/OS/C library did you use?
>> Obviously
>>  >> there will be *some* overhead having the extra memcmp() in there but
>> does it
>>  >> matter? For example, if the overhead is just 1-2s on a 30s query then
>> that
>>  >> doesn't really matter. Then again, if the overhead is 1s on a 3s query
>> then
>>  >> that is significant.
>>  >> Since this is a new feature then I'd be inclined to say that for a first
>> cut
>>  >> we should keep the standard API, and depending on the reports we get
>> back,
>>  >> look at improving it later. That seems a lot more preferable to having a
>>  >> fairly nasty API hack that will catch a lot of people out :(
>>  >> ATB,
>>  >> Mark.
>>  >> Mark Cave-Ayland
>>  >> Sirius Corporation - The Open Source Experts
>>  >> http://www.siriusit.co.uk
>>  >> T: +44 870 608 0063
>>  >> _______________________________________________
>>  >> postgis-devel mailing list
>>  >> postgis-devel at postgis.refractions.net
>>  >> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>>  Martin Davis
>>  Senior Technical Architect
>>  Refractions Research, Inc.
>>  (250) 383-3022
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080401/6dd2ede9/attachment.html>
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080401/6dd2ede9/attachment.vcf>
