API for optimized predicates (was Re: [postgis-devel] 1.3.3)
Paul Ramsey pramsey at cleverelephant.ca
Tue Apr 1 18:08:25 PDT 2008
Right. So, unsurprisingly, the 2-param case returned the same timing,
since it *was* the same code line.
The 3-param case I ran was ST_Contains(ed.the_geom, v.centroid,
ed.gid), so the numeric case, not the NULL case.
P
On Tue, Apr 1, 2008 at 5:26 PM, Chris Hodgson <chodgson at refractions.net> wrote:
> Hmm... good point, when you say "2-param" case do you mean passing a
>  NULL to the 3-param version? Because I think the 2-param version IS the
>  usual un-prepared approach, which would explain your results... unless
>  I'm misunderstanding Ben's patch...
>  Chris
>  Ben Jubb wrote:
>  > for the 3 param version, where you using an integer key, or NULL?
>  > b
>  > Paul Ramsey wrote:
>  >> I gave this a try, but in the three-parameter case it caused the
>  >> backend to crash and in the two-parameter case provided the same speed
>  >> as the usual un-prepared approach...
>  >> I was testing with st_contains(polycolumn, pointcolumn), with 80 polys
>  >> and 7000 points.
>  >> P
>  >> On Mon, Mar 31, 2008 at 3:50 PM, Ben Jubb <benjubb at refractions.net> wrote:
>  >>>  Hiya,
>  >>>  I've attached a patch to lwgeom_geos_c.c, modifying its 1st arg caching
>  >>> behaviour.
>  >>>  The third argument is used as before, as a surrogate key, and the caching
>  >>> will use that as its key;
>  >>>  UNLESS the key is NULL.
>  >>>  If the key is NULL, the predicates use the memcmp technique to determine if
>  >>> the cached prepared geometry is in sync with the first arg.
>  >>>  Note that the two caching approaches have essentially independent caches.
>  >>>  This patch is intended for testing purposes only.
>  >>>  enjoy
>  >>>  b
>  >>>  Paul Ramsey wrote:
>  >>>  A unique-on-insert ID would be another approach. It would, however,
>  >>> involve a disk-format change, so we're talking about pretty big
>  >>> hammers here, regardless of whether we did a hash or a uuid.
>  >>> Ben, maybe just stick some small timing statements into your current
>  >>> code... start time, end time, and then do a noop memcmp with start/end
>  >>> times as well. That way we can compare the memcmp times to the total
>  >>> times.
>  >>> P.
>  >>> On Mon, Mar 31, 2008 at 10:17 AM, Martin Davis <mbdavis at refractions.net>
>  >>> wrote:
>  >>>  (renaming this thread, since the current one is way overloaded)
>  >>>  I agree with Paul and Mark - there should be a simple function signature
>  >>>  for the fast preds. The more complex one can be provided as well, but
>  >>>  it will need to be VERY well documented, since it's a tricky thing to grok.
>  >>>  re spatial hash - would you really trust a hash to confirm identity? I
>  >>>  don't think I would...
>  >>>  Would another alternative would be to assign a hidden unique ID to each
>  >>>  geom entered into the DB. This could be a honking big integer, or maybe
>  >>>  a UUID.
>  >>>  Paul Ramsey wrote:
>  >>>  > The problem is that the memcmp hit gets worse in exactly the cases
>  >>>  > were we expect better and better performance from the prepared
>  >>>  > algorithm... still, it would be nice to know what that hit is...
>  >>>  > compared to the original, unprepared time, it will be small, but
>  >>>  > compared to the prepared-with-id-API implementation... hard to say.
>  >>>  > Something to resolve before 1.4... It's unfortunate that all the
>  >>>  > *fast* tests can only falsify identity, not confirm it. I was talking
>  >>>  > to a fellow who has done a spatial db implementation on a proprietary
>  >>>  > system, and he was pleased with the idea of a "geographic hash" that
>  >>>  > he can calculate for each shape and use to test identity. If we were
>  >>>  > to do something like that, it would have to be optional, like the bbox
>  >>>  > calculation is currently.
>  >>>  > P.
>  >>>  > On Mon, Mar 31, 2008 at 2:51 AM, Mark Cave-Ayland
>  >>>  > <mark.cave-ayland at siriusit.co.uk> wrote:
>  >>>  >> On Friday 28 March 2008 23:53:53 Ben Jubb wrote:
>  >>>  >> > Howdy,
>  >>>  >> > In my testing, I did see a performance hit when using the memcmp test,
>  >>>  >> > although it was noticable only in the largest of my test geometries
>  >>>  >> > (5000 vertices or so).
>  >>>  >> > The three parameter form seemed like the best way to go because the
>  >>>  >> > whole point of the prepared version of the functions was to get the
>  >>> best
>  >>>  >> > possible performance. The cases when the performance matters most is
>  >>>  >> > with large geoms, and then the cost of doing the memcmp is the
>  >>> highest.
>  >>>  >> > Using a third argument seemed the simplest way to get the best
>  >>> possible
>  >>>  >> > performance from the predicates, with a minimal increase in the
>  >>>  >> > complexity of the interface.
>  >>>  >> > I agree it would be nice to have a single form for those predicates
>  >>> that
>  >>>  >> > automatically determines the most efficient manner to do the tests,
>  >>> but
>  >>>  >> > there didn't seem to be any efficient way to accomplish that.
>  >>>  >> > b
>  >>>  >> Hi Ben,
>  >>>  >> Well I think it really comes down to what exactly is the performance hit
>  >>> and
>  >>>  >> how did you measure it? Which platform/OS/C library did you use?
>  >>> Obviously
>  >>>  >> there will be *some* overhead having the extra memcmp() in there but
>  >>> does it
>  >>>  >> matter? For example, if the overhead is just 1-2s on a 30s query then
>  >>> that
>  >>>  >> doesn't really matter. Then again, if the overhead is 1s on a 3s query
>  >>> then
>  >>>  >> that is significant.
>  >>>  >> Since this is a new feature then I'd be inclined to say that for a first
>  >>> cut
>  >>>  >> we should keep the standard API, and depending on the reports we get
>  >>> back,
>  >>>  >> look at improving it later. That seems a lot more preferable to having a
>  >>>  >> fairly nasty API hack that will catch a lot of people out :(
>  >>>  >> ATB,
>  >>>  >> Mark.
>  >>>  >> Mark Cave-Ayland
>  >>>  >> Sirius Corporation - The Open Source Experts
>  >>>  >> http://www.siriusit.co.uk
>  >>>  >> T: +44 870 608 0063
>  >>>  >> _______________________________________________
>  >>>  >> postgis-devel mailing list
>  >>>  >> postgis-devel at postgis.refractions.net
>  >>>  >> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>  >>>  Martin Davis
>  >>>  Senior Technical Architect
>  >>>  Refractions Research, Inc.
>  >>>  (250) 383-3022
