API for optimized predicates (was Re: [postgis-devel] 1.3.3)
Paul Ramsey pramsey at cleverelephant.ca
Wed Apr 2 16:16:33 PDT 2008
Nice catch.
Without STRICT, the ST_Contains(g,g,null) case returns about 5% slower
than the id-tested case from my unpatched copy of postgis.  The
id-tested case in the patched copy blows up, which is odd, since I
can't see any real changes in that case from the original.
P.
On Wed, Apr 2, 2008 at 3:56 PM, Mark Leslie <mark.leslie at lisasoft.com> wrote:
> Mark Leslie wrote:
> > ST_Contains(geometry, geometry, integer) is defined as 'isstrict'.  This
> is a PostgreSQL optimization that will cause the function to return null
> anytime any argument is null.
> > I'm sure it's screaming fast though.
>  Sorry, I didn't get that quite right.  ST_Contains is not strict, but it
> calls _ST_ContainsPrepared which is.
>  Mark Leslie
>  Geospatial Software Architect
>  LISAsoft Pty Ltd
>  +61 (0)2 8570 5050
>  Commercial Support for Geospatial Open Source Software
>  http://www.lisasoft.com/LISAsoft/SupportedProducts.html
>  _______________________________________________
>  postgis-devel mailing list
>  postgis-devel at postgis.refractions.net
>  http://postgis.refractions.net/mailman/listinfo/postgis-devel
