[postgis-devel] PostGIS Development Roadmap
Obe, Regina robe.dnd at cityofboston.gov
Thu Apr 17 04:41:16 PDT 2008
> Stripping out dead code
> If we are happy to require PostgreSQL >= 8.1 for future versions then
> there is a lot of dead code that can be removed, specifically with
> regard to statistics / GiST indexes. It would help tidy up the code
base
> a lot :)
Do we know how many people are still using 8.0?  Maybe we can do a poll
of some sort either via the PostGIS newsgroup or the PostgreSQL website
(if we can get away with that).  I think the PostGIS newsgroup has
fairly high-end users so may not be a good measure - although if the
number is high on that, then we definitely have issues.
I wouldn't mind dumping pre 8.0 installs as I think you've got way too
many issues if you are running below 8.0 that you probably wouldn't be
considering using PostGIS anyway and you would get a bad impression of
it if you were running in that environment.
8.1 seems cutting it close as it seems a lot of ISPs I've dealt with
seem to only support 8.0.  Then again if you are only running 8.0 and
relying on a shared box, you have other unsurmounting issues anyway.  As
long as we keep the old versions available and patched as needed its
probably a non-issue.
> So... there is a lot of work on this list which we really need to
think
> about doing. Since the changes are quite involved, I am leaning
towards
> working in a separate branch and then switching it to HEAD when
> something actually works for some more testing.
+1
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
