[postgis-devel] Math expressions in documentation
Obe, Regina robe.dnd at cityofboston.gov
Fri Aug 1 08:45:08 PDT 2008
Kevin,
not that it matters - I had a typo in my message to you.  I'm running
OpenSUSE 10.3  not OpenSolaris.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of
Kevin Neufeld
Sent: Friday, August 01, 2008 11:33 AM
To: PostGIS Development Discussion
Subject: [postgis-devel] Math expressions in documentation
Hi folks,
I seem to be having a little trouble with the math expressions in the
documentation.  In ST_Crosses
(http://postgis.refractions.net/documentation/manual-svn/ST_Crosses.html
and ST_Touches, I added the mathematical expressions straight out of the
OGC specifications as gif images.  I mucked around with MathML for a
while, trying to get that to work with Docbook ... gave up and resorted
to using simple HTML characters (which don't seem to render properly
some versions of IE and Firefox, as well as different build environments
- it breaks on Regina's Solaris box, but builds fine on my Fedora box)
In particular, this won't work:
<para>
   <equation>a.Crosses(b) ⇔ (dim(I(a) ∩ I(b)) <
max(dim(I(a)),dim(I(b))) ∧ (a ∪ b ≠ a) ∧ (a ∪ b ≠
b)</equation>
</para>
Any suggestions?  Does anyone have experience with MathML?  It's really
rather simple, but my Fedora box takes forever loading the MathML DTD.
Or should we simply just leave them as images?
Cheers,
Kevin
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
