[postgis-devel] PATCH: Documentation spelling fixes.
Mak Kolybabi mak_kolybabi at umanitoba.ca
Sat Aug 2 11:41:46 PDT 2008
I just started learning how to use PostGIS for work this week, and while reading
the documentation a few minor spelling mistakes started bugging me. I apologize
if this is not the appropriate way to submit a patch, but I could not find any
instructions on the website for it.
(patch attached)
Matthew Anthony Kolybabi (Mak)
<mak_kolybabi at umanitoba.ca>
() ASCII Ribbon Campaign | Against HTML e-mail
/\  www.asciiribbon.org  | Against proprietary extensions
Index: README.postgis
--- README.postgis	(revision 2911)
+++ README.postgis	(working copy)
@@ -126,14 +126,14 @@
 Where [prefix] above is extracted by `pg_config --configure`.
 You can change them using ./configure switches.
-See CONFIGURARION section.
+See CONFIGURATION section.
 CREATING NEW SPATIAL DATABASES
 PostGIS support must be enabled for each database that requires
 its usage. This is done by feeding the lwpostgis.sql (the enabler script)
-file to the targed database.
+file to the target database.
 The enabler script requires the PL/pgSQL procedural language in order
 to operate correctly, you can use the 'createlang' program from the
Index: doc/introduction.xml
--- doc/introduction.xml	(revision 2911)
+++ doc/introduction.xml	(working copy)
@@ -132,7 +132,7 @@
       </listitem>
       <listitem>
-        <para>More information about Mapserver internet map server is
+        <para>More information about MapServer internet map server is
         available at <ulink
         url="http://mapserver.gis.umn.edu/">http://mapserver.gis.umn.edu</ulink>.</para>
       </listitem>
Index: doc/release_notes.xml
--- doc/release_notes.xml	(revision 2911)
+++ doc/release_notes.xml	(working copy)
@@ -40,7 +40,7 @@
       <para>This release provides performance enhancements to the relational
       functions, adds new relational functions and begins the migration of our
-      function names to the SQL-MM convension, using the spatial type (SP)
+      function names to the SQL-MM convention, using the spatial type (SP)
       prefix.</para>
       <simplesect>
@@ -71,7 +71,7 @@
         <para>Extended curved geometry support into the geometry accessor and
         some processing functions</para>
-        <para>Began migration of functions to the SQL-MM naming convension;
+        <para>Began migration of functions to the SQL-MM naming convention;
         using a spatial type (ST) prefix.</para>
         <para>Added initial support for PostgreSQL 8.3</para>
Index: doc/reference.xml
--- doc/reference.xml	(revision 2911)
+++ doc/reference.xml	(working copy)
@@ -98,7 +98,7 @@
             <para>Refer to
             http://lin-ear-th-inking.blogspot.com/2007/06/subtleties-of-ogc-covers-spatial.html
-            for an explaination of the need of this function.</para>
+            for an explanation of the need of this function.</para>
           </listitem>
         </varlistentry>
@@ -366,7 +366,7 @@
           <term>ST_GeometryN(geometry,nth integer)</term>
           <listitem>
-            <para>Return the N'th geometry if the geometry is a
+            <para>Return the Nth geometry if the geometry is a
             GEOMETRYCOLLECTION, MULTIPOINT, MULTILINESTRING or MULTIPOLYGON.
             Otherwise, return NULL.</para>
@@ -391,7 +391,7 @@
           <term>ST_PointN(geometry,nth integer)</term>
           <listitem>
-            <para>Return the N'th point in the first linestring in the
+            <para>Return the Nth point in the first linestring in the
             geometry. Return NULL if there is no linestring in the
             geometry.</para>
@@ -460,7 +460,7 @@
           <term>ST_InteriorRingN(geometry,nth integer)</term>
           <listitem>
-            <para>Return the N'th interior ring of the polygon geometry.
+            <para>Return the Nth interior ring of the polygon geometry.
             Return NULL if the geometry is not a polygon or the given N is out
             of range.</para>
@@ -1080,7 +1080,7 @@
           <term>ST_length_spheroid(geometry,spheroid)</term>
           <listitem>
-            <para>Calculates the length of of a geometry on an ellipsoid. This
+            <para>Calculates the length of a geometry on an ellipsoid. This
             is useful if the coordinates of the geometry are in
             latitude/longitude and a length is desired without reprojection.
             The ellipsoid is a separate database type and can be constructed
@@ -1105,7 +1105,7 @@
           <term>ST_length3d_spheroid(geometry,spheroid)</term>
           <listitem>
-            <para>Calculates the length of of a geometry on an ellipsoid,
+            <para>Calculates the length of a geometry on an ellipsoid,
             taking the elevation into account. This is just like
             length_spheroid except vertical coordinates (expressed in the same
             units as the spheroid axes) are used to calculate the extra
Index: doc/README
--- doc/README	(revision 2911)
+++ doc/README	(working copy)
@@ -8,7 +8,7 @@
 Rules are:
 	make html # output in html/postgis.html
-	make chuncked-html
+	make chunked-html
 	make postgis.pdf
Index: doc/faq.xml
--- doc/faq.xml	(revision 2911)
+++ doc/faq.xml	(working copy)
@@ -11,7 +11,7 @@
       <answer>
         <para>You can store point, line, polygon, multipoint, multiline,
         multipolygon, and geometrycollections. These are specified in the Open
-        GIS Well Known Text Format (with XYZ,XYM,XYZM extentions).</para>
+        GIS Well Known Text Format (with XYZ,XYM,XYZM extensions).</para>
       </answer>
     </qandaentry>
@@ -185,8 +185,8 @@
         suggested that you do use <varname>AddGeometryColumn()</varname> to
         create geometry tables.</para>
-        <para>Mapserver is one application which makes use of the
-        <varname>geometry_columns</varname> meta-data. Specifically, Mapserver
+        <para>MapServer is one application which makes use of the
+        <varname>geometry_columns</varname> meta-data. Specifically, MapServer
         can use the SRID of the geometry column to do on-the-fly reprojection
         of features into the correct map projection.</para>
       </answer>
