[postgis-devel] RECHECK not supported in PsotgreSQL HEAD any more?
Chris Hodgson chodgson at refractions.net
Thu Aug 7 09:56:13 PDT 2008
Isn't the recheck still needed because of the difference in precision
between the bbox and the actual data? Or is this not really a concern?
Chris
Jorgen Austvik - Sun Norway wrote:
> Hi,
> I tried running the PostGIS tests against PostgreSQL HEAD, and got
> this error message:
> --------8<---------------8<---------------8<---------------8<-------
> psql:lwpostgis.sql:1040: ERROR:  RECHECK is no longer supported
> HINT:  Update your data type.
> psql:lwpostgis.sql:1053: ERROR:  current transaction is aborted,
> commands ignored until end of transaction block
> It seems that it is OK to remove the RECHECKs?:
> http://postgis.refractions.net/pipermail/postgis-users/2007-September/017036.html
> The applied patch removes the RECHECKs (and all the tests pass without
> them on RHEL 5.1), but I have no idea whether that is the correct
> thing to do or not - so please don't apply them without looking into
> the matter ;-) (They might be needed on earlier versions of PsotgreSQL?)
> -J
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
