[postgis-devel] Lame attempt at cascade union in sql
Kevin Neufeld kneufeld at refractions.net
Thu Aug 7 22:22:35 PDT 2008
Hmmm.  Still, I give you an applause for the speed an simplicity of your
attempt.  Even my crazy looking GROUPBY/ORDERBY query that runs in 1min
is still 3 times slower than Martin Davis's Java code in JTS.  Ideally,
it would be best for someone to put the thing through GEOS so PostGIS
can benefit from it as well.  Anyone feel like brushing up on their C?  :)
-- Kevin
Obe, Regina wrote:
> Curiosity got the better of me this time so I ran thru the full set
> once and got this.  So still better, but I guess there is still room
> for improvement and my cascading seems to not be growing linearly as
> Kevin's is.
> --277,656 ms = 4.6276 minutes
> SELECT ST_CascadeUnion(the_geom)
> FROM (SELECT * FROM sample_poly) As foo;
> --69,953 ms = 1.16 minutes
> SELECT ST_Union(the_geom) AS the_geom
> FROM (
>    SELECT min(id) AS id, ST_Union(the_geom) AS the_geom
>    FROM (
>      FROM (
>        FROM (
>          GROUP BY round(id/10)
>          ORDER BY id) AS tmp1
>        GROUP BY round(id/100)
>        ORDER BY id) AS tmp2
>      GROUP BY round(id/1000)
>      ORDER BY id) AS tmp3
>    GROUP BY round(id/10000)
>    ORDER BY id) AS tmp4
> GROUP BY round(id/100000);
