[postgis-devel] Lame attempt at cascade union in sql
Mateusz Loskot mateusz at loskot.net
Fri Aug 8 09:27:00 PDT 2008
Martin Davis wrote:
> Java is much more efficient at memory allocation than C++ is (at
> least, using std C++ memory operations). So barring a stroke of
> genius in GEOS-land I think JTS is alway going to out-perform.
A bit OT, but I can and can not agree.
GC allocation implements more sophisticated allocation strategies and is
typically faster than manually new'ed/malloc'ed storage in C/C++.
But allocating everything in dynamic storage on the heap, costs a lot.
In C++, programmer can and should follow the rule of "no allocation
costs nothing" and prefer stack wherever possible.
In GEOS, I've found it as a major problem. GEOS mimics Java approach
almost directly without incorporating C++ patterns and optimizations.
Next issue is that standard containers in C++ use standard allocators
that solve most common cases and guarantee robustness on all platforms.
For special conditions, it's highly recommended to invent dedicated
allocators and use them with standard containers.
Custom allocators in C++ are likely out-perform Java allocators + its
cost of garbage collector.
p.s. I hope I've hit principles of substantive discussion and you won't
get my post as a holly war. Flame is not my intention.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
