[postgis-devel] More Cascade Union Adventures
Martin Davis mbdavis at refractions.net
Wed Aug 13 17:08:15 PDT 2008
While pondering OJ's failure to complete the union on this dataset, I
realized that one trick that CascadedUnion uses is that when unioning
two MultiPolygons, it *avoids* unioning polygon components which lie
outside the intersection of the envelopes of the two input geometries.
Those polygon components will be left unchanged by the union, and so can
just be added in afterwards.  This can make a big difference when large
far-flung polygons are being unioned - as is the case with this dataset.
Not sure if you can use this technique in your algorithm - seems like it
might be tricky to express in SQL.
Obe, Regina wrote:
> Try this set.  - this has 2895 records
> My timings are
> ---time 161,047 ms = SELECT 161047/1000.0/60 = 2.68 minutes
> SELECT ST_CascadeUnion(the_geom)
> from usstatebounds;
> --time 121719 ms = SELECT 121719/1000.0/60 = 2.02 minutes
> SELECT st_unitecascade_garray_sort(ARRAY(SELECT the_geom FROM
> usstatebounds));
> In OJ - it gets to the last round and then fails with a Java out of
> Heap space error.
> *The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended solely for the
> addressee. If you received this in error, please contact the sender
> and delete the material from any computer. *
> * Help make the earth a greener place. If at all possible resist
> printing this email and join us in saving paper. *
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
