[postgis-devel] Issue 37 in postgis: ST_Intersection throws error on postgis Linux installation
codesite-noreply at google.com codesite-noreply at google.com
Thu Aug 14 15:08:06 PDT 2008
Issue 37: ST_Intersection throws error on postgis Linux installation
http://code.google.com/p/postgis/issues/detail?id=37
Comment #3 by luigi.cardeles:
hum i run the first query (1) and obtain that:
POLYGON((1364172.42114192 5512319.07956828,1364166.71443533
5512317.04910436,1364166.7144 5512317.0492,1364172.42112749
5512319.07956315,1364172.42114192 5512319.07956828)).
there is a little difference about the decimal (i know, very little
difference,
almost insignificant) but why that? I am just curious.
I am running postgres 8.3.3 - postgis 1.3.3 - geos 3.0.0 at AMD 64 bits.
Thanks
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
