[postgis-devel] Issue 47 in postgis: Avoiding notices upon import	of lwpostgis.sql
    codesite-noreply at google.com
    Wed Aug 20 11:07:02 PDT 2008
Issue 47: Avoiding notices upon import of lwpostgis.sql
http://code.google.com/p/postgis/issues/detail?id=47
Comment #2 by dane.springmeyer:
And a link to a good explanation for the notices after another user is
concerned:
http://postgis.refractions.net/pipermail/postgis-users/2006-November/013995.html
This leads me to believe that the notices will not be avoided until postgis
requires postgres 8.2?
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
