[postgis-devel] Updated SVN documentation
Obe, Regina robe.dnd at cityofboston.gov
Fri Aug 22 10:26:07 PDT 2008
Mark,
I made some changes based on your input.  Feel free to correct anywhere I went wrong.
Admittedly I'm very new to Linux and a lot of commands are still cryptic to me.  A lot of the instructions I curled from the PostGIS thread.
http://postgis.refractions.net/pipermail/postgis-users/2008-August/020746.html
And I liked them - whether right or wrong - because they required very little thought on my part, didn't require searching the web to figure out where do I get geos, or proj or whatever
and of course they worked for me :).
I'm still in a bit of disagreement of the hard-coding of links to dependencies.
On the one hand I see your point, but on the other hand - my thinking is the relationship between the proj, postgis, and geos camps is very close that we can easily correct any links that are broken and people can easily do a google to find a broken link or submit a bug to complain.
I think the convenience of having the link right there and ability to copy and paste is useful and the statement that - for x version of PostGIS, these are the preferred versions of these packages to use.
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080822/e1acfabf/attachment.html>
