[postgis-devel] Updated SVN documentation
Obe, Regina robe.dnd at cityofboston.gov
Thu Aug 28 14:48:11 PDT 2008
> Looking over at it again today, I think the changes I would like to see
> would be:
> - Remove section 2.2.1 part 2 as this is reasonably redundant with autoconf
> (I find this confusing as it states that we need to check the versions of
> tools listed, but then doesn't state which versions are needed?)
> - Move the sections 2.2.1 parts 3/4 about compiling PROJ/GEOS out of the
> main instruction flow and put it in a separate section below
> Do you think that this would be a reasonable compromise?
Mark take a look at the doc changes and let me know if that looks more appealing.  I also corrected the urls to proj and geos projects since those were pointing at the non-osgeo locations.
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080828/a797693d/attachment.html>
