[postgis-devel] Issue 34 in postgis: .prj creation by pgsql2shp
codesite-noreply at google.com codesite-noreply at google.com
Tue Dec 2 05:33:48 PST 2008
Updates:
	Status: Accepted
	Labels: Milestone-1.4
Comment #2 on issue 34 by robe.... at cityofboston.gov: .prj creation by
pgsql2shp
http://code.google.com/p/postgis/issues/detail?id=34
Working on this now and have a testing version working, but have not
committed it
yet.  Will commit first draft to trunk probably within the next week.
Slight change -- to above -- I have the logic currently just outputting the
prj based
on the SRID of the geometry so no need to prompt for what SRID that I can
think of.
I'm debating whether we still need a switch to denote whether to
disable .prj output.
Right now my logic will output a .prj file by default if a query/table has a
well-defined SRID and only one SRID, but I'm thinking there are cases where
users may
want to manually generate their own .prj file and therefore may not want
the system
to overwrite that.  Suggestions are welcome.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
