[postgis-devel] Issue 78 in postgis: CheckAuth - doesn't check if trigger exists before trying to create it also why return 0
codesite-noreply at google.com codesite-noreply at google.com
Tue Dec 2 11:40:58 PST 2008
Status: Accepted
Owner: robe.... at cityofboston.gov
Labels: Type-Defect Priority-Low
New issue 78 by robe.... at cityofboston.gov: CheckAuth - doesn't check if
http://code.google.com/p/postgis/issues/detail?id=78
This is actually marked as a TODO in the code
-- TODO: check for an already existing trigger ?
I guess we are also thinking about this.
What is the point of returning 0 vs. true/false or a meaningful text
message?
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
