[postgis-devel] Issue 74 in postgis: AddGeometryColumn does not detect search_path properly
codesite-noreply at google.com codesite-noreply at google.com
Tue Dec 2 12:25:54 PST 2008
Comment #4 on issue 74 by robe.... at cityofboston.gov: AddGeometryColumn does
http://code.google.com/p/postgis/issues/detail?id=74
Haven't tried running the code but on spot inspection I see a problem.
Looks like you also replaced GeometryType call with ST_GeometryType, but
GeometryType
returns something like 'POINT', 'POLYGON' etc. as I recall and
ST_GeometryType
returns 'ST_Point', 'ST_Polygon' etc.  Isn't that a breaking change.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
