[postgis-devel] Issue 79 in postgis: shp2pgsql does not honor -s
codesite-noreply at google.com codesite-noreply at google.com
Wed Dec 3 06:00:56 PST 2008
Status: Accepted
Owner: pwramsey3
Labels: Type-Defect Milestone-1.4 Usability OpSys-All Priority-High
New issue 79 by pwramsey3: shp2pgsql does not honor -s
http://code.google.com/p/postgis/issues/detail?id=79
1. Use the -s option, try to load the result.
The AddGeometryColumn call specifies the requested SRID, but the geometries
in the load file do
not have the right SRID set. As a result they fail the check constraint.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
