[postgis-devel] Issue 53 in postgis: Flesh out spatial ref sys section
codesite-noreply at google.com codesite-noreply at google.com
Wed Dec 3 09:20:40 PST 2008
Comment #2 on issue 53 by robe.... at cityofboston.gov: Flesh out spatial ref
sys section
http://code.google.com/p/postgis/issues/detail?id=53
Dane - actually I did work on this a bit a couple of months back.  Take a
look at the
SVN doc section to see if you think things look clear enough or if more
changes need
to be made.
http://postgis.refractions.net/documentation/manual-svn/ch04.html#spatial_ref_sys
If it looks okay to you I'll close this out.  If not feel free to give me a
patch for
changes.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
