[postgis-devel] Issue 34 in postgis: .prj creation by pgsql2shp
codesite-noreply at google.com codesite-noreply at google.com
Wed Dec 3 12:00:45 PST 2008
Comment #8 on issue 34 by robe.... at cityofboston.gov: .prj creation by
pgsql2shp
http://code.google.com/p/postgis/issues/detail?id=34
Just noticed I left some conditions that I no longer need since the
coalesce will
always return a record except on fatal error where table does not exist or
connection
is lost.  I'll take those out later.
Still thinking about Mark's comment about just outputting the .prj
regardless.  I'll
leave like that for now, but still have some reservations.  Unlike the
tables and shp
that rightfully do get overwritten, a .prj file is valid for a table query
even from
previous dumps.  I'll have to reinstall my ArcGIS and play with that.
My concern is if you store your data in a certain projection which is
equivalent to
another registered in say ArcGIS or mapinfo, but yours isn't.  You may
manually
create a .prj to make <stuff your favorite yuck product here> happy and not
want the
.prj overwritten though you always want the latest data overritten.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
