[postgis-devel] Issue 80 in postgis: ST_Multi seg faults
codesite-noreply at google.com codesite-noreply at google.com
Thu Dec 4 14:34:28 PST 2008
Comment #1 on issue 80 by mark.cav... at siriusit.co.uk: ST_Multi seg faults
http://code.google.com/p/postgis/issues/detail?id=80
Hmmmm. I get this on 1.4.0SVN (x86_64):
postgis=# SELECT ST_Multi('MULTILINESTRING((0 0,1 1))');
ERROR:  Dimensions mismatch in lwcurve
Looks similar to the error message that was reported by William Kyngesburye
when
trying to clean geometries...
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
