[postgis-devel] st_mullti() issue in PostGIS 1.3.4
Obe, Regina robe.dnd at cityofboston.gov
Fri Dec 5 09:26:52 PST 2008
This problem is already fixed.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net on behalf of Paul Ramsey
Sent: Fri 12/5/2008 12:21 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] st_mullti() issue in PostGIS 1.3.4
Crazy, LINESTRING, POINT, MULTIPOINT, MULTIPOLYGON all seem to work...
P.
On Thu, Dec 4, 2008 at 2:16 PM, Kevin Neufeld <kneufeld at refractions.net> wrote:
> Confirmed. I get the same thing with 1.4.0SVN.
> -- Kevin
> Carl Anderson wrote:
>> I just upgraded to PostgGIS 1.3.4 from PostGIS 1.3.2 and am now getting
>> segfaults with
>> select st_multi('MULTILINESTRING((0 0,1 1))');
>> Does this blow up for anyone else?
>> C.
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081205/9d05a819/attachment.html>
