[postgis-devel] CLUSTER in 8.3
    Paul Ramsey
    pramsey at cleverelephant.ca
    Fri Dec  5 12:01:24 PST 2008
Works with btree.
pramsey=# create table ttt as select * from counties;
SELECT
pramsey=# create index gid_bix on ttt (gid);
CREATE INDEX
pramsey=# select count(*) from ttt;
 count
  3141
(1 row)
pramsey=# cluster ttt using gid_bix;
CLUSTER
 count
  3141
(1 row)
On Fri, Dec 5, 2008 at 11:49 AM, Chris Hodgson <chodgson at refractions.net> wrote:
> Kevin Neufeld wrote:
>> Mark Cave-Ayland wrote:
>>  > I think the GiST part is a red herring - there is no way that a "SELECT
>>> COUNT(*) FROM foo" can use an index in PostgreSQL. My suspicion is that
>>> it's related to the use of ANALYZE/VACUUM/CLUSTER.
>> Maybe.  You're right that "SELECT ..." doesn't use the index, but the
>> CLUSTER physically reorders the table based on the index.  If there is a
>> bizzare bug in our GiST implementation that produces an empty traversal list
>> some of the time, the table would be empty.
>> Never mind, I just saw Paul's post.  This is good news for us in that it's
>> not related to our implementation of GiST ...  but it still could be related
>> to PostgreSQL's implementation, no?
> Well, can anyone replicate the problem by clustering on a non-gist index? If
> so, then we should really be able to just throw this problem at the Postgres
> Devs. I'd be surprised if this was the case though, I can't believe no-one
> else would have come across this yet...
> Chris
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
