[postgis-devel] Issue 81 in postgis: This geometry causes buffer(?, 0) to crash the PostGresql server
codesite-noreply at google.com codesite-noreply at google.com
Tue Dec 9 01:43:18 PST 2008
Comment #2 on issue 81 by mark.cav... at siriusit.co.uk: This geometry causes
http://code.google.com/p/postgis/issues/detail?id=81
In that case, this is probably a "WontFix" and should be reposted onto the
tracker at http://trac.osgeo.org/geos. Anyone object?
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
