[postgis-devel] Issue 34 in postgis: .prj creation by pgsql2shp
codesite-noreply at google.com codesite-noreply at google.com
Tue Dec 9 02:04:23 PST 2008
Comment #10 on issue 34 by mark.cav... at siriusit.co.uk: .prj creation by
pgsql2shp
http://code.google.com/p/postgis/issues/detail?id=34
I've quickly reviewed your applied patch and have a couple of minor
comments:
- Even though you've used malloc() instead if snprintf(), I still think the
calculation is wrong. In the code, you have "if ( schema ) size +=
strlen(schema)",
but then in the first query you reference schema twice. So I'm thinking
this should
be something like "size += 2 * strlen(schema)" instead. And this may also
be the same
for the table name and the geo-column name.
- Slight typo in your block comment (havshort)
- protect_quotes_string_noiconv(). I don't think you need this, as code to
handle
this is already built into libpq. See
http://www.postgresql.org/docs/8.3/interactive/libpq-exec.html#LIBPQ-EXEC-ESCAPE-STRING
for some examples.
HTH,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
