[postgis-devel] Issue 34 in postgis: .prj creation by pgsql2shp
codesite-noreply at google.com codesite-noreply at google.com
Tue Dec 9 04:19:00 PST 2008
Comment #11 on issue 34 by robe.... at cityofboston.gov: .prj creation by
pgsql2shp
http://code.google.com/p/postgis/issues/detail?id=34
Thanks Mark.  I suspected there was such a thing in libq, but couldn't find
an
example use in the code.  I stole much of that code from shp2pgsql but that
had a lot
of iconv stuff that would have required me bringing too much stuff over.
You think
the same holds true for that part or we still in the protect_quotes_string
for that
part because of the need for iconv checks.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
