[postgis-devel] Issue 81 in postgis: This geometry causes buffer(?, 0) to crash the PostGresql server
codesite-noreply at google.com codesite-noreply at google.com
Tue Dec 9 04:39:07 PST 2008
Comment #4 on issue 81 by mark.cav... at siriusit.co.uk: This geometry causes
http://code.google.com/p/postgis/issues/detail?id=81
Ah I see. Normally the procedure is to try the geometry in GEOS by
converting to
XMLTester format, and if it crashes there then it's definitely a GEOS
rather than
PostGIS issue.
HTH,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
