[postgis-devel] Issue 34 in postgis: .prj creation by pgsql2shp
codesite-noreply at google.com codesite-noreply at google.com
Wed Dec 10 06:20:12 PST 2008
Comment #13 on issue 34 by robe.... at cityofboston.gov: .prj creation by
pgsql2shp
http://code.google.com/p/postgis/issues/detail?id=34
Okay I looked at PQescapeStringConn() and seems kind of cumbersome to use
since it
takes the string in as a pointer changes it and then just outputs the size
of the
resulting so I'd have to have silly variables to contend with it seems.
Unless I
misunderstood that.  Couldn't find any examples of its use either.
I'm actually thinking of abandoning the whole printf ... query thing and
using
PQexecParams instead which seems to have existed at least since 8.0.
http://www.postgresql.org/docs/8.3/interactive/libpq-exec.html.  I think
that will
also solve the having to make the buffer big enough issue if I use a
parameterized
query.  Does that sound reasonable?
Though no examples of that I could find either so I'm hoping they have some
examples
in the PostgreSQL source code so I don't actually have to learn C to make
sense of
the documentation.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
