[postgis-devel] The Garden Test
Obe, Regina robe.dnd at cityofboston.gov
Thu Dec 11 11:06:18 PST 2008
I've committed my first version of what I shall call the Garden Test.
Its an xsl file that when applied to the reference_new.xml generates
an sql file that looks like the attached file.
Right now it just pulls all the aggregates and unary functions from the docs that take geometries and tests them against generate_series (points, lines, polygons
I also do against an ST_Multi of the above geometries to test multi geometries.
I know the spacing sucks and eventually I plan to just have an array of geometries
to test against.  but its a start.
Feel free to test on your builds.  Have only tested on 1.3.3 (which of course it failed on populate_geom.. and Asgeojson, but will test later on on 1.3.5SVN and 3.1
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081211/c382e9ab/attachment.html>
Type: application/octet-stream
Desc: gardentest.sql
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081211/c382e9ab/attachment.obj>
