[postgis-devel] getPoint2d_p
Paul Ramsey pramsey at cleverelephant.ca
Sat Dec 13 18:55:55 PST 2008
On Sat, Dec 13, 2008 at 4:34 PM, strk <strk at keybit.net> wrote:
> On Sat, Dec 13, 2008 at 04:19:42PM -0800, Paul Ramsey wrote:
>> I'm looking at the simple distance calculating function, and I see this:
>> double lwgeom_pointarray_length2d(POINTARRAY *pts)
>>         double dist = 0.0;
>>         int i;
>>         POINT2D frm;
>>         POINT2D to;
>>         if ( pts->npoints < 2 ) return 0.0;
>>         for (i=0; i<pts->npoints-1;i++)
>>                 getPoint2d_p(pts, i, &frm);
>>                 getPoint2d_p(pts, i+1, &to);
>>                 dist += sqrt( ( (frm.x - to.x)*(frm.x - to.x) )  +
>>                                 ((frm.y - to.y)*(frm.y - to.y) ) );
>>         return dist;
>> That's simple enough... but what burns me is that getPoint2d_p does this:
>> int
>> getPoint2d_p(const POINTARRAY *pa, int n, POINT2D *point)
>>         memcpy(point, getPoint_internal(pa, n), sizeof(POINT2D));
>>         return 1;
>> We're just reading, why the memcpy? Sure, it's pretty darn fast, hand
>> optimized assembler by the gods of gcc and all that, but surely it
>> would nicer to just get a pointer into a structure.
>> All this derives from having our point arrays stored in "uchar
>> *serialized_pointlist" the primary advantage being ... ?
> Using what postgresql gives us IIRC.
> IE: tipically our POINTARRAY is just some bytes into what we get out of
> PG_DETOAST_DATUM, if we force interpretation of it as a double*,
> memory alignemtn constraints of the hosting machine may disagree.
> On some machines a double* can't be at arbitrary memory locations, but
> only at addresses which are multiples of sizeo(double). So if you take this
> layout:
>  X      XXXXXXX XXXXXXXX XXXXXX
>  header  point1  point2   point3
> your points are not aligned to 'double' boundary.
> The layout was an example, see the internal representation of GEOMETRY
> type for a more accurate layout.
We know that PG_DETOASTDATUM does a memcpy already, can't we arrange
our structure so that with VARHDRSZ our doubles land on a 64-bit
boundary?
P.
> --strk;
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
