[postgis-devel] Issue 83 in postgis: ST_Multi on curved polygon gives ERROR: Unknown geometry type: 0
codesite-noreply at google.com codesite-noreply at google.com
Mon Dec 15 03:47:23 PST 2008
Updates:
	Status: Fixed
Comment #4 on issue 83 by robe.... at cityofboston.gov: ST_Multi on curved
http://code.google.com/p/postgis/issues/detail?id=83
Thanks that worked for me and I was able to put it back into torture
script.  I
thought it was that that was causing a later service crash in ST_Collect on
CurvedPolygon.  I'm investigating that one to see if it was an issue in
1.3.3.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
