[postgis-devel] Issue 85 in postgis: ST_Distance crashes on Circular String
codesite-noreply at google.com codesite-noreply at google.com
Mon Dec 15 04:44:32 PST 2008
Status: Accepted
Owner: robe.... at cityofboston.gov
Labels: Milestone-1.4
New issue 85 by robe.... at cityofboston.gov: ST_Distance crashes on Circular
String
http://code.google.com/p/postgis/issues/detail?id=85
What steps will reproduce the problem?
1. SELECT ST_Distance(ST_GeomFromText('CIRCULARSTRING(220268 150415,220227
150505,220227 150406)'), ST_Point(220268, 150415))
What is the expected output? Unsupported or a number
What do you see instead? Crashes server
This occurs on 1.3.3 and 1.3.5SVN (not verified on 1.4) so long standing
issue.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
