[postgis-devel] Issue 87 in postgis: Probe_Geometry_Columns does not parse an SRID of -1
codesite-noreply at google.com codesite-noreply at google.com
Tue Dec 16 13:38:27 PST 2008
Status: Started
Owner: ke... at refractions.net
Labels: Type-Defect Priority-Medium Milestone-1.3.X
New issue 87 by ke... at refractions.net: Probe_Geometry_Columns does not
parse an SRID of -1
http://code.google.com/p/postgis/issues/detail?id=87
probe_geometry_columns() does not properly parse an srid check constraint
with an SRID of -1.
I committed a small patch to trunk that seems to resolve the issue, but
it'll need to get back ported to 1.3.
-- Kevin
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
