[postgis-devel] Issue 85 in postgis: ST_Distance crashes on Circular String
codesite-noreply at google.com codesite-noreply at google.com
Wed Dec 17 06:59:33 PST 2008
Comment #2 on issue 85 by mark.cav... at siriusit.co.uk: ST_Distance crashes
on Circular String
http://code.google.com/p/postgis/issues/detail?id=85
Yup, it seems to be getting stuck somewhere in
lwgeom_mindistance2d_recursive_tolerance. Anyone with CircularString
knowledge able
to work out what is supposed to be happening here?
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
