[postgis-devel] Trouble compiling 1.4 under MingW
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Thu Dec 18 05:14:38 PST 2008
Obe, Regina wrote:
> Now that I finally have my MinGW environment sort of working.
> 1) I was able to successfully compile the 1.3 SVN branch under MinGW
> But when I attempted to accomplish the same feat for 1.4 -- I get the
> below error when doing the
> sh autogen.sh
> $ sh autogen.sh
> configure.ac:108: error: possibly undefined macro: AS_HELP_STRING
>       If this token and others are legitimate, please use
> m4_pattern_allow.
>       See the Autoconf documentation
Yeah. The autotools version supplied with MingW is ancient, so I think I
had to download the latest versions from GNU and install them in MingW.
Alternatively, you can run ./autogen.sh on a Linux box and copy the
resulting configure across to your MingW machine, or in theory the
1.4SVN snapshot .tar.gz should contain configure pre-generated by the
automated build system.
HTH,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
