[postgis-devel] Issue 88 in postgis: pgsql2shp crashes on Vista
codesite-noreply at google.com codesite-noreply at google.com
Mon Dec 22 04:34:07 PST 2008
Updates:
	Status: Testing
Comment #1 on issue 88 by robe.... at cityofboston.gov: pgsql2shp crashes on
Vista
http://code.google.com/p/postgis/issues/detail?id=88
After discussion with Mark -- made final change.  Tested this on OpenSUSE
and Windows
XP.  Still need to retest on Vista (both binary and non-binary).  Issue was
the way
we were releasing non-binary geom fields which it appears only Vista was
sensitive
to.  Needed to change to use PQfreemem instead of free for newer versions
of PostGIS.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
