[postgis-devel] Updates to GEOS & POSTGIS
Paul Ramsey pramsey at refractions.net
Mon Jan 21 12:44:28 PST 2008
Historically, we've left sql.in along and put in stubbed functions in
the .c files, in the case of with-GEOS versus without-GEOS.  We could
go whole hog and add GEOS version detection to ./configure.  Might
make things even worse for VCC workers.
As of now, having trolled the code base, there is a geos_version.sh
script which can write the version into a #define for use elsewhere.
The only running code that works with version is the run-time version
print-out in postgis_geos_version().
The most elegant thing would be to put it into ./configure, IMO, but
I'm not sure that's the most *useful* thing.
P
On Jan 21, 2008, at 11:45 AM, Ben Jubb wrote:
> My changes won't build against the GEOS 3.0.0 branch.  use the trunk
> instead.
> I'm open to suggestions as to how to get the GEOS version
> information into lwpostgis.sql.in.
> cheers
> b
> Mark Cave-Ayland wrote:
>> On Fri, 2008-01-18 at 09:26 -0800, Ben Jubb wrote:
>>> Mark,
>>> thanks for the comments,
>>> - I'll change the comment style..
>>> - added the initGEOS() calls, oops..
>>> - the size calculation: ill try your suggestion for getting
>>> arg1_length.
>> Hi Ben,
>> I've just done a checkout of latest SVN, and unfortunately it seems
>> broken against the GEOS 3.0.0 branch :(
>> I managed to get around the compilation failures by removing the line
>> "#define PREPARED_GEOM 0", but regression tests fail because
>> lwpostgis.sql.in still references these functions, and hence it
>> fails to
>> load into PostgreSQL.
>> So in order to support both newer and older versions of GEOS, there
>> needs to be some GEOS versioning directives around the new code in
>> both
>> lwpostgis.sql.in and lwgeom_geos_c.c (rather than having to alter
>> both
>> of these by hand).
>> ATB,
>> Mark.
> <benjubb.vcf>_______________________________________________
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
