[postgis-devel] Updates to GEOS & POSTGIS
Ben Jubb benjubb at refractions.net
Mon Jan 21 16:25:41 PST 2008
Fixed version of lwgeom_geos_c.c checked in.
Paul Ramsey wrote:
> That's good. I didn't realize we had a GEOS version string floating
> around for the pre-processor to grab. What I meant was exactly what
> you did, there should be other examples wrapped inside the USE_GEOS
> define, for the "ain't got no GEOS" case.
> P
> On Jan 21, 2008, at 2:45 PM, Ben Jubb wrote:
>> I wrapped the bodies of the new functions I added to lwgeom_geom_c.c
>> with an #if test for the right version of the GEOS lib, along with an
>> #else part that throws a 'not implemented' error.  This particular
>> source file is definitely dependent on the GEOS library.  If the
>> older version of GEOS is used, the 'prepared' functions will throw an
>> error.  I don't think this will cause a link error.
>> Im not sure what you are refering to as 'GEOS stubs'.
>> b
>> Paul Ramsey wrote:
>>> I'm not sure that will work, since the symbols for the new functions
>>> will be missing in the older versions... might we not end up with a
>>> link-time error?  The thing about the GEOS stubs is that they are
>>> wrapped in a USE_GEOS define that removes the library dependency.
>>> P
>>> On Jan 21, 2008, at 1:24 PM, Ben Jubb wrote:
>>>> Ill implement your first suggestion, and stub the C functions for
>>>> the prepared stuff, moving the version detection to the
>>>> lwgeom_geos_c.c.  Seems friendliest to the long suffering VS users.
>>>> b
>>>> Paul Ramsey wrote:
>>>>> Historically, we've left sql.in along and put in stubbed functions
>>>>> in the .c files, in the case of with-GEOS versus without-GEOS.  We
>>>>> could go whole hog and add GEOS version detection to ./configure.
>>>>> Might make things even worse for VCC workers.
>>>>> As of now, having trolled the code base, there is a
>>>>> geos_version.sh script which can write the version into a #define
>>>>> for use elsewhere.  The only running code that works with version
>>>>> is the run-time version print-out in postgis_geos_version().
>>>>> The most elegant thing would be to put it into ./configure, IMO,
>>>>> but I'm not sure that's the most *useful* thing.
>>>>> P
>>>>> On Jan 21, 2008, at 11:45 AM, Ben Jubb wrote:
>>>>>> My changes won't build against the GEOS 3.0.0 branch.  use the
>>>>>> trunk instead.
>>>>>> I'm open to suggestions as to how to get the GEOS version
>>>>>> information into lwpostgis.sql.in.
>>>>>> cheers
>>>>>> b
>>>>>> Mark Cave-Ayland wrote:
>>>>>>> On Fri, 2008-01-18 at 09:26 -0800, Ben Jubb wrote:
>>>>>>>> Mark,
>>>>>>>> thanks for the comments,
>>>>>>>> - I'll change the comment style..
>>>>>>>> - added the initGEOS() calls, oops..
>>>>>>>> - the size calculation: ill try your suggestion for getting
>>>>>>>> arg1_length.
>>>>>>> Hi Ben,
>>>>>>> I've just done a checkout of latest SVN, and unfortunately it seems
>>>>>>> broken against the GEOS 3.0.0 branch :(
>>>>>>> I managed to get around the compilation failures by removing the
>>>>>>> line
>>>>>>> "#define PREPARED_GEOM 0", but regression tests fail because
>>>>>>> lwpostgis.sql.in still references these functions, and hence it
>>>>>>> fails to
>>>>>>> load into PostgreSQL.
>>>>>>> So in order to support both newer and older versions of GEOS, there
>>>>>>> needs to be some GEOS versioning directives around the new code
>>>>>>> in both
>>>>>>> lwpostgis.sql.in and lwgeom_geos_c.c (rather than having to
>>>>>>> alter both
>>>>>>> of these by hand).
>>>>>>> ATB,
>>>>>>> Mark.
>>>>>> <benjubb.vcf>_______________________________________________
>>>>>> postgis-devel mailing list
>>>>>> postgis-devel at postgis.refractions.net
>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080121/9ac4bbfa/attachment.vcf>
