[postgis-devel] WKT and Wikipedia
Paul Ramsey
pramsey at cleverelephant.ca
Wed Jul 2 15:54:00 PDT 2008
Be liberal in what you accept and strict in what you emit. The
question is, whose rules should we adhere to? I guess, really the new
rules are the only super-official ones, since the old SFSQL never
actually went beyond 2D.
P.
On Mon, Jun 30, 2008 at 3:25 PM, Kevin Neufeld <kneufeld at refractions.net> wrote:
> That is a good question. Since it looks like we going to break people code
> anyway ... to be true to the spec, I assume this also means that the parser
> should error out if someone tried to supply 3 or 4 dimensions without using
> the POINT Z, POINT M, or POINT ZM syntax.
> We could try to be backwards compatible and continue to allow the use of
> 'POINT' for 3D/4D coordinates, but as Martin pointed out, we would no longer
> be compliant with the standard since the OGC standard itself is not
> backwards compatible.
> Choose your poison, eh?
> -- Kevin
> Paul Ramsey wrote:
>> Yes, handling POINT M, POINT Z, and POINT ZM is a good thing for 1.4.
>> That's an addition to the parser (I can put my new lex/yacc book to
>> use :). The hard question is what to *emit* in response to an
>> ST_AsText() :)
>> P.
>> PS - those are the ISO wkt forms too.
>> On Fri, Jun 27, 2008 at 4:42 PM, Kevin Neufeld <kneufeld at refractions.net>
>> wrote:
>>> So, the 1.2 OGC specs require that the WKT of Z, M, and ZM be:
>>> POINT <point text>
>>> POINT Z <point z text>
>>> POINT M <point m text>
>>> POINT ZM <point zm text>
>>> PostGIS has:
>>> POINT <point text> | <point z text>
>>> POINTM <point m text> | <point zm text>
>>> To me, this means PostGIS is not entirely OGC compliant. (ie. PostGIS
>>> can't
>>> parse an OGC compliant WKT string)
>>> postgis=# SELECT 'POINT ZM(0 0 0 0)'::geometry;
>>> ERROR: parse error - invalid geometry
>>> Same goes for the textual representation of other geometries.
>>> ie. LINESTRING ZM (...)
>>> Should we add this to the TODO list for 1.4? Or is there a specs gray
>>> area
>>> ... that we're compliant enough.
>>> -- Kevin
>>> Martin Davis wrote:
>>>> Actually the latest SFS 1.2 spec does include a spec for 2D measured, 3D
>>>> 3D measured WKT. See here:
>>>> http://www.opengeospatial.org/standards/sfa
>>>> (This is also referenced on the wiki page)
>>>> Kevin Neufeld wrote:
>>>>> I just came across this page:
>>>>> http://en.wikipedia.org/wiki/Well-known_text
>>>>> I think this page is incorrect, misleading, and contains typos. It is
>>>>> my
>>>>> understanding that the OGC specs on WKT does *not* include 3D and 4D
>>>>> definitions. It is a PostGIS extension to use Z, M, or ZM. Or am I off
>>>>> on
>>>>> this?
>>>>> (http://portal.opengeospatial.org/files/?artifact_id=829) (section
>>>>> 3.2.5.2)
>>>>> I don't have an account to correct this. Does any here have one? Do
>>>>> we
>>>>> care?
>>>>> Should the new PostGIS docs reference such pages, or point to only the
>>>>> OGC specs?
>>>>> -- Kevin
>>>>> _______________________________________________
>>>>> postgis-devel mailing list
>>>>> postgis-devel at postgis.refractions.net
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
