[postgis-devel] Rebranding proposal for SVN HEAD
Obe, Regina robe.dnd at cityofboston.gov
Thu Jul 3 06:56:20 PDT 2008
> I can't say that I'm too excited about that one - I like just being
able
> to have an active PostGIS database with a single psql command. OTOH it
> should be possible to generate a single.sql file from multiple sources
>  as part of the build process if that helps?
Actually I like that idea better of just having one .sql file to run.  I
guess I wanted to separate the function definition  from the metadata
comments - since it would be conceivably separate people working on each
and/or if we are generating the meta data comments directly from the
docs it would seem harder to upgrade if those comments are intermingled
with the function definitions.
So would something like
postgis_core.sql.in , postgis_comments.sql.in -> postgis.sql
be doable?
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
