[postgis-devel] PostGIS documentation on refractions.net website
Kevin Neufeld kneufeld at refractions.net
Thu Jul 3 09:10:20 PDT 2008
I also think it's a good idea.  I was thinking something similar myself.
Except I don't think your naming convention works.  If /docs is an alias
for /docs/1.3, then /docs/1.4 would expand to /docs/1.3/1.4.  I think we
would have to either use a different folder structure (like
/docs_static/1.3) or put a redirect page at /docs/index.html (perhaps
something along the lines of http://www.postgresql.org/docs/).
I'm not aware of any hidden build-results file.  Though that would be a
good thing to have.
-- Kevin
Mark Cave-Ayland wrote:
> Hi there,
> Given that there have been some changes to the configure options in SVN,
> I'd like to propose a change in the website documentation process.
> Currently SVN HEAD is extracted and built on postgis.refractions.net,
> but since many people refer to this directly online I can see this being
> a source of confusion.
> What I think would be a good solution would be the following:
> - Generate 1.3 series documentation @
> http://postgis.refractions.net/docs/1.3/ from the SVN 1.3 branch
> - Generate 1.4 series documentation @
> http://postgis.refractions.net/docs/1.4/ from SVN HEAD
> - Alias http://postgis.refractions.net/docs onto the 1.3 series
> documentation which represents the current latest release.
> Would this be something that would be easily achievable? And also how do
> I check any errors that may result from the building the documentation
> for the website? Is this available as a hidden file somewhere in the web
> tree?
> ATB,
> Mark.
