[postgis-devel] WKT and Wikipedia
Paul Ramsey
pramsey at cleverelephant.ca
Thu Jul 3 10:33:07 PDT 2008
That would be wise. It won't protect against breaking, but it will at
least make it easy to retrofit old code without re-writing it
completely.
On Thu, Jul 3, 2008 at 9:43 AM, Martin Davis <mbdavis at refractions.net> wrote:
> Agreed.
> Although this is still going to break a lot of code that expects the old
> style WKT. Perhaps it would be possible to provide a function which
> produces the old style for a few releases?
> Paul Ramsey wrote:
>> Be liberal in what you accept and strict in what you emit. The
>> question is, whose rules should we adhere to? I guess, really the new
>> rules are the only super-official ones, since the old SFSQL never
>> actually went beyond 2D.
>> P.
>> On Mon, Jun 30, 2008 at 3:25 PM, Kevin Neufeld <kneufeld at refractions.net>
>> wrote:
>>> That is a good question. Since it looks like we going to break people
>>> code
>>> anyway ... to be true to the spec, I assume this also means that the
>>> parser
>>> should error out if someone tried to supply 3 or 4 dimensions without
>>> using
>>> the POINT Z, POINT M, or POINT ZM syntax.
>>> We could try to be backwards compatible and continue to allow the use of
>>> 'POINT' for 3D/4D coordinates, but as Martin pointed out, we would no
>>> longer
>>> be compliant with the standard since the OGC standard itself is not
>>> backwards compatible.
>>> Choose your poison, eh?
>>> -- Kevin
>>> Paul Ramsey wrote:
>>>> Yes, handling POINT M, POINT Z, and POINT ZM is a good thing for 1.4.
>>>> That's an addition to the parser (I can put my new lex/yacc book to
>>>> use :). The hard question is what to *emit* in response to an
>>>> ST_AsText() :)
>>>> P.
>>>> PS - those are the ISO wkt forms too.
>>>> On Fri, Jun 27, 2008 at 4:42 PM, Kevin Neufeld
>>>> wrote:
>>>>> So, the 1.2 OGC specs require that the WKT of Z, M, and ZM be:
>>>>> POINT <point text>
>>>>> POINT Z <point z text>
>>>>> POINT M <point m text>
>>>>> POINT ZM <point zm text>
>>>>> PostGIS has:
>>>>> POINT <point text> | <point z text>
>>>>> POINTM <point m text> | <point zm text>
>>>>> To me, this means PostGIS is not entirely OGC compliant. (ie. PostGIS
>>>>> can't
>>>>> parse an OGC compliant WKT string)
>>>>> postgis=# SELECT 'POINT ZM(0 0 0 0)'::geometry;
>>>>> ERROR: parse error - invalid geometry
>>>>> Same goes for the textual representation of other geometries.
>>>>> ie. LINESTRING ZM (...)
>>>>> Should we add this to the TODO list for 1.4? Or is there a specs gray
>>>>> area
>>>>> ... that we're compliant enough.
>>>>> -- Kevin
>>>>> Martin Davis wrote:
>>>>>> Actually the latest SFS 1.2 spec does include a spec for 2D measured,
>>>>>> 3D
>>>>>> 3D measured WKT. See here:
>>>>>> http://www.opengeospatial.org/standards/sfa
>>>>>> (This is also referenced on the wiki page)
>>>>>> Kevin Neufeld wrote:
>>>>>>> I just came across this page:
>>>>>>> http://en.wikipedia.org/wiki/Well-known_text
>>>>>>> I think this page is incorrect, misleading, and contains typos. It
>>>>>>> is
>>>>>>> my
>>>>>>> understanding that the OGC specs on WKT does *not* include 3D and 4D
>>>>>>> definitions. It is a PostGIS extension to use Z, M, or ZM. Or am I
>>>>>>> off
>>>>>>> on
>>>>>>> this?
>>>>>>> (http://portal.opengeospatial.org/files/?artifact_id=829) (section
>>>>>>> 3.2.5.2)
>>>>>>> I don't have an account to correct this. Does any here have one? Do
>>>>>>> we
>>>>>>> care?
>>>>>>> Should the new PostGIS docs reference such pages, or point to only
>>>>>>> the
>>>>>>> OGC specs?
>>>>>>> -- Kevin
>>>>>>> _______________________________________________
>>>>>>> postgis-devel mailing list
>>>>>>> postgis-devel at postgis.refractions.net
>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> Martin Davis
> Senior Technical Architect
> Refractions Research, Inc.
> (250) 383-3022
