[postgis-devel] Reprojection issues
Nico Mandery nico.mandery at geops.de
Fri Jul 4 00:10:50 PDT 2008
Mark Cave-Ayland schrieb:
> Nico Mandery wrote:
>> Hello list,
>> I got a problem reprojecting geometries from EPSG:3785 (the Google or
>> Web Mercator projection) to WGS84 (EPSG:4236).
>> For example when I try to transform one point postgis gives me the
>> following - correct - result:
>> projects=# select
>> astext(st_transform(GeomFromText('POINT(879650.162980923
>> 6108535.16589579)',3785),4326));
>>                  astext
>> POINT(7.90203186083991 48.0100993171653)
>> (1 row)
>> When I try it again with exactly the same query, I get a wrong result
>> and an error from libproj:
>> projects=# select
>> WARNING:  transform: -38 (failed to load NAD27-83 correction file)
>>                      astext
>> POINT(1.23892476139034e-06 7.52729195068025e-06)
>> (1 row)
>> Every following query will also return wrong results, until I close
>> the connection to the database. The first query after establishing a
>> new connection to postgresql returns a correct result again, every
>> following raises the error again.
>> The NAD correction files exist. Transforming coordinates with cs2cs
>> from libproj works without any problems.
>> I tried it with Postgresql 8.2.4 and 8.3.3 and postgis 1.3.2 and
>> 1.3.3. The proj4text in spatial_ref_sys for EPSG:3785 is
>> "+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0
>> +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs"
>> Thanks a lot,
>> Nico
> Hi Nico,
> I'm not sure about the +wktext part of your proj4text as I've never
> seen that before - so maybe it is an invalid PROJ.4 string? What
> happens if you try the transformation using the standard proj executable?
> ATB,
> Mark.
Hi Mark,
I'm using the same Proj.4 string in the epsg-file of the proj libray. As
far as I can see the +wktext part does not seem to matter - the results
stay the same with or without it. Reprojections using the cs2cs tool
from proj are working correctly - whats also my workaround for this
problem right now.
regards,
Nico
