[postgis-devel] ST_MakePolygon returns null geometry when passedNULL or empty array
Kevin Neufeld kneufeld at refractions.net
Tue Jul 8 10:53:44 PDT 2008
Hi Regina,
I get the same as you. It looks like quirkiness of postgres if you ask me.
As a second parameter to ST_MakePolygon, I agree these all produce
different results:
ARRAY(SELECT 'LINESTRING EMPTY'::geometry WHERE false)
-> produces a valid polygon with no holes
ARRAY[NULL]
-> errors on "hole 0 is not a line"
NULL
-> produces no polygon, just null
I think the best course is to be clear in the docs that the second
parameter must not be null and must be a valid set of LINESTRINGs,
passing ST_IsValid.
Cheers,
-- Kevin
Obe, Regina wrote:
> Okay this is puzzling me.  I wasn't getting errors, just getting NULL back.
> What do you get if you run this
> SELECT ST_IsValid(the_geom), ST_AsText(the_geom)
> FROM (
>    SELECT ST_MakePolygon(
>      'LINESTRING(0 0, 0 8, 8 8, 8 0, 0 0)'::geometry,
>      ARRAY(SELECT 'LINESTRING(1 1, 0 8, 8 8, 8 0, 1 1)'::geometry WHERE
> false)) AS the_geom
>    ) AS foo;
> The test I ran should have been the same as this, but this actually
> works the way I would expect it to returning a geometry when given an
> empty geometry array.  Although I just ran on 1.3.2  and I think earlier
> I was testing on 1.3.3 and it was slightly more complicated than the
> above so I'll need to retry my example to make sure I was mistaken and
> its not just a version difference.
> Just plain null - doesn't give me an error as an ARRAY[NULL] but returns
> NULL
> FROM (
>      NULL) AS the_geom
>    ) AS foo;
> Thanks,
> Regina
