[postgis-devel] ST_MakePolygon returns null geometry	when	passedNULL or empty array
    Kevin Neufeld
    kneufeld at refractions.net
    Wed Jul  9 09:11:41 PDT 2008
As a geometry constructor, this method is similar to the WKT or WKB
parser which don't currently test for validity.  As MarkC pointed out a
few emails ago (in the "Removing geometry parsing checks" thread),
isvalid() calls are heavyweight and expensive to make.
Oh the other hand, this method is fundamentally different than the WKT/B
parser in that it's highly unlikely to be used in any sort of bulk
loading.  So maybe the performance hit for testing for validity (and
throwing a NOTICE if necessary) is not so bad?  It would probably be the
only geometry constructor that tests for validity though.
Cheers,
Kevin
Obe, Regina wrote:
> On the robust side of things should we be concerned that if we feed it
> closed line strings that are not contained in the shell (or is the
> shell) and/or overlap each other.  The function happily returns you an
> invalid geometry.
>  SELECT ST_IsValid(the_geom), ST_AsText(the_geom)
> FROM (
>    SELECT ST_MakePolygon(
>      'LINESTRING(0 0, 0 8, 8 8, 8 0, 0 0)'::geometry,
>      ARRAY['LINESTRING(0 0, 0 8, 8 8, 9 0, 0 0)'::geometry]) AS the_geom
>    ) AS foo;
> seems like it should give you a NOTICE or something.
