[postgis-devel] GeoJson patch
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Mon Jul 14 03:48:09 PDT 2008
Courtin Olivier wrote:
> Yes, that was a mess !
> The previous applied GeoJson patch (r2842), fix this behaviour.
Ah yes, I see now.
> As this unit test is not really meaningfull (prototype function check is
> PostgreSQL job, not the
> PostGIS function one), i've just decided to remove it.
> An alternative would be to use tests cases upon PostgreSQL version in a
> geojson_expected.in
> (quite similar than JTS checks for curves units tests)
Well the current version information is available within both the 1.3
branch and SVN trunk Makefiles, so I'll leave it up to you to determine
whether or not you consider the test important enough to be included.
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
