[postgis-devel] Configure step - Mac OsX
Courtin Olivier
olivier.courtin at camptocamp.com
Mon Jul 14 04:11:05 PDT 2008
On Jul 14, 2008, at 12:49 PM, Mark Cave-Ayland wrote:
Mark,
>> I'm currently re-working the missing linker flag part of the patch
>> (and will apply shortly). The problem was I didn't realise that
>> LIBS didn't get automatically set if the AC_CHECK_LIB() action-if-
>> found is set.
> This is now done - please can you do an "svn up" and re-test at your
> end?
- ./configure --help is nice and clean ;)
- liconv flags works too
- ./configure step (without any option) end with following error:
configure: error: the docbook stylesheet directory specified using --
with-xsldir does not exist
Following code is a working workaround,
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080714/3a0c3a54/attachment.obj>
HTH,
Olivier
