[postgis-devel] Issue 42 in postgis: Postgis Docbook CSS upgrade
Kevin Neufeld kneufeld at refractions.net
Mon Jul 14 14:28:32 PDT 2008
I like it.  Much improved, Dane.  Good job!
Dane Springmeyer wrote:
> Thanks Paul,
> And here's an html version for reference:
> http://danespringmeyer.com/tmp/postgis_alt_css.html
> Looks like the background colors do not come through for the <code>
> <pre> and <note> tags in the pdf version (if that is desirable I'll need
> to look into why that is...)
> Dane
> On Jul 14, 2008, at 1:47 PM, Paul Ramsey wrote:
>> Looks good to me. Not hearing any objections, I'll swap this in
>> shortly. I've attached a PDF of hte output for those who want to see
>> without testing themselves.
>> On Mon, Jul 14, 2008 at 1:29 PM,  <codesite-noreply at google.com> wrote:
>>> Issue 42: Postgis Docbook CSS upgrade
>>> http://code.google.com/p/postgis/issues/detail?id=42
>>> New issue report by dane.springmeyer:
>>> With the various enhancements and efforts going into the PostGIS
>>> documentation currently, I think
>>> the CSS could use an upgrade as well.
>>> The main room for improvement I see in the CSS/formatting is the
>>> handling of
>>> code examples and
>>> notes. If these distinct sections (which are being expanded
>>> currently) were
>>> more distinctly formatted
>>> with color or background it would help the readability of the docs.
>>> I've attached a patch and the corresponding file for an alternate css
>>> that
>>> fits my taste. I offer it
>>> purely as an alternative or a starting point. I noticed the recent
>>> addition
>>> of blue and orange
>>> branding of the official Postgis Refractions site and therefore
>>> pulled from
>>> those colors a bit.
>>> Suggestions to improve it are welcome, and if it is acceptable to the
>>> developers integration into the
>>> codebase is fine.
>>>       style.css  2.5 KB
>>>       style.diff  3.2 KB
>>> Issue attributes:
>>>       Status: New
>>>       Owner: ----
>>>       Labels: Type-Defect Priority-Medium
>>> You received this message because you are listed in the owner
>>> or CC fields of this issue, or because you starred this issue.
>>> You may adjust your issue notification preferences at:
>>> http://code.google.com/hosting/settings
>>> postgis-devel mailing list
>>> postgis-devel at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>> <PostGIS 1.3.4 Manual.pdf>_______________________________________________
