[postgis-devel] Issue 31 in postgis: Negative distance buffer
codesite-noreply at google.com codesite-noreply at google.com
Wed Jul 16 03:42:59 PDT 2008
Issue 31: Negative distance buffer
Comment #4 by mark.cav... at siriusit.co.uk:
I apologise if this has fallen from the radar, it seems that most of
the developers
(including myself) are busy with other projects at the moment. One
thing that would
be a great help would be to determine whether or not the problem is
caused by just
GEOS or PostGIS' interaction with GEOS.
If you could run your POLYGONs through GEOS' XMLTester and compare the
results with
PostGIS, then this would be a helpful starting point.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
